IOGEAR GPUL02 BLACK CHARGE AND SYNC PRO CABLE - USB TO LIGHTNING CABLE
IOGEAR GPUL02 Black Charge & Sync Pro Cable - USB to Lightning Cable Type: Lightning Cable Compatible Phone Manufacturer: Apple Length: 6.5 Feet Adapter: Lightning Port Standard USB Port: 0 Specifications: POP Information 10'' Peg Hook 7 6'' Peg Hook 4 Unit Dimensions Height 0.625" (1.59cm) Depth 0.31" (0.78cm) Length 80.49" (204cm) Unit Wt. 0.11lb (0.05kg) Features: Compatible with all Apple® Lightning devices Cotton/nylon fiber weave cable jacket for increased durability Molded connectors with double-bonded strain relief for maximum cable life Oversized conductor diameter provides better power transfer 6.5ft (2m) length Easy grip, tangle free, and stain resistant Warranty: Manufacturer's Warranty
Price: 15.29
