IOGEAR GPUL01 BLACK CHARGE AND SYNC PRO CABLE - USB TO LIGHTNING CABLE
IOGEAR GPUL01 Black Charge & Sync Pro Cable - USB to Lightning Cable Type: Lightning Cable Compatible Phone Manufacturer: Apple Length: 3.3 Feet Adapter: Lightning Port Standard USB Port: 0 Specifications: POP Information 10'' Peg Hook 7 6'' Peg Hook 4 Unit Dimensions Height 0.63" (1.59cm) Depth 0.31" (0.78cm) Length 40.75" (103cm) Unit Wt. 0.068lb (0.031kg) Features: Compatible with all Apple® Lightning devices Woven nylon/cotton jacket increases durability Oversized conductor diameter provides better power transfer 3.3ft (1m) length Easy grip, tangle free, and stain resistant Warranty: Manufacturer's Warranty
Price: 15.99
